It is currently Mon Aug 04, 2025 3:35 pm
 Post subject: Tight bend on maple
PostPosted: Sun Feb 15, 2009 5:20 pm
First name: Randolph
Last Name: Morris
I am getting ready to bind the a headstock with roughly .062 square maple. There are two tight bends that are somewhere between the size of a nickle and a dime. What recommendations do you have? How can I best keep the grain from peeling up on the outside of the bend? My plan is to use a pipe to bend it on. The fretboard and the body will be bound with curly maple. Is it too much to ask to use figured grain on that tight of a bend?
 Post subject: Re: Tight bend on maple
PostPosted: Sun Feb 15, 2009 6:03 pm
You may have to break a few pieces, but those are short and easily replaceable. I wouldn't wet curly maple too much. I use a soldering iron and a wet paper towel laid on it to do those tight bends for the hand stops. Unless you have the Ibex and mando extension rod…
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sun Feb 15, 2009 7:05 pm
use a backer. I have a little piece of flexible metal (think metal side slat) with two wood blocks screwed into the ends to hold onto. That helps a lot.
you can also use a damp cloth over your pipe to help even out the heat. I have found that helps too, and helps with scorching.
I actually have pretty good luck with maple. Obviously the thinner you make it the easier it is to bend.
PostPosted: Sun Feb 15, 2009 7:09 pm
Last Name: Morris
Thanks Brock. Laurent says to use minimal moisture directly on the wood. Do you find this to be true also? Is the rag enough by itself?
Users browsing this forum: Ken Lewis and 11 guests
